DEVELOPERS FORUM - ECO Impact Matrix Reference Designator
jsnosal - Friday, October 26, 2012 4:15 PM:
Is there a reason why the impact matrix doesn't handle reference designators? Is there an area where I can add the reference designator to the impact matrix? Thank you
zahar - Sunday, November 4, 2012 3:20 AM:
You can update method that creates the ImpactMatrix grid: "Express ECO ImpactMatrix Handler" and add your columns
jsnosal - Tuesday, November 6, 2012 10:15 AM:
Thank you for your help. The reference designation is now in the impact matrix. I'm having an issue when I'm about to approve the ECO. I'm getting an affected relationship error, saying that it did not write to the part. If I look at the part I can see the reference designation did change inside the Part BOM tab. Any ideas on how to fix this? Thanks
Verifications failed: Property 'reference_designator' was not set to value 'R1' for Affected Relationship 'EBC97BE307A648C4B70C7CE2435F3D5B'.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="schemas.xmlsoap.org/.../" xmlns:i18n="www.aras.com/I18N">
<SOAP-ENV:Body>
<SOAP-ENV:Fault>
<faultcode>1</faultcode>
<faultactor></faultactor>
<faultstring>Verifications failed: Property 'reference_designator' was not set to value 'R1' for Affected Relationship 'EBC97BE307A648C4B70C7CE2435F3D5B'.</faultstring>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
