zahar - Sunday, November 4, 2012 3:50 AM:
I'm wondering if there is option to assign more than 1 workflow (map) to ItemType - how i can do following:
- Assign 2 Workflow maps to Simple ECO (current one and new one)
- When user will use "Add item to Change" and select Simple ECO he will get some dialog that will ask him with of workflow map he want to use
- If this is not possible, is there an option after new Simple ECO created (but not saved) - user can change workflow map?
fli - Wednesday, November 14, 2012 4:26 AM:
Hi Zahar,
How about using Lifecycle states to kick off the Workflows ?
Ask the user, then depending on the answer promote the Item to the Lifecycle state where the needed Workflow is stated.
/ Christoffer
dennis - Monday, January 7, 2013 4:00 PM:
I typically solve this by hooking the workflow maps to the itemtype but do not set a default. Then I hook the onAfterAdd server event of the eco itemtype. The method determines which workflow to start (I typically use the classification but you could use a list or checkbox on the eco form). After that, the method starts the appropriate workflow. Here is some pseudo code.
switch (classification)
case "Major":
wflMapName = "Major ECO";
break;
case "Minor":
wflMapName = "Minor ECO";
break;
zahar - Wednesday, November 14, 2012 6:16 AM:
Nice Idea! I'll try it
