DEVELOPERS FORUM - Java Web Service login issue: "You are not logged in to Innovator."
Jayateertha - Friday, December 7, 2012 3:50 PM:
Dear Gurus,
Here is the brief info about my issue:
1. I've created a web service in ARAS and trying to use it in my java application using ksoap2 APIs. I was trying to make use of ApplyAml method by passing a string value of "<AML><Item type='User' action='get'/></AML>".
2. However, when I invoke the Soap call, I'm getting the error of -
"Aras.Tools.WebServices.LogOnException: ERROR: You are not logged in to Innovator."
3. Moreover, I even tried invoking ApplyAml method's Test section under the following URL
   localhost/.../Innovator.asmx
   I could pass - value as stated below:
Parameter:
Value
aml
                           "Invoke" Button.
   After I click on "Invoke" button, I'm getting the same error which was stated above:
 It would be great if somebody can tell us the required essential steps (preferably in sequential manner) which are required to invoke web services using Java.
Thanks & Regards,
Jayateertha.
