DEVELOPERS FORUM - Using Sort() to reorder a list by date
Simone.C - Friday, December 7, 2012 5:06 AM:
I'm trying to use the C# function Sort() to reorder a list of activities that I've created, but I get an error that I could not solve.
The problem is that to use Sort() I need to implement the IComparable interface (or Comparer<T>.Default), that I can't implement.
Has anyone had the some problem?
Do I have to modify the Item class and add the IComparable interface? How should I modify the Item class to implement this interface? I can't find the source file of item class....
This is the code I wrote and the error message:
Innovator myInnovator = this.getInnovator();
//retrieve the activity of open projects
var activity_results = myInnovator.applyMethod("GetActivities", "<string></string>");
//create and populate the list with the results of the query
List<Item> activities = new List<Item>();
for(int i = 0; i < activity_results.getItemCount(); i++)
   activities.Add(activity_results.getItemByIndex(i));
//sort the activities
activities.Sort()
