DEVELOPERS FORUM - getAssignedActivities() not Given Result
nilesh_jos - Monday, December 17, 2012 6:55 AM:
hi All,
I have already active and pending activities  and i use getAssignedActivities() method from outside aras.It  gives empty shop result like below.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="schemas.xmlsoap.org/.../SOAP-ENV:Envelope>
Nilesh
Boro - Wednesday, January 9, 2013 9:34 PM:
Hello Nilesh,
getAssignedActivities() method requires two parameters. Did you set these parameter correctly?
public function getAssignedActivities(state : String, userID : String)
You can check the details of this method in API Reference.
nilesh_jos - Friday, January 11, 2013 11:36 AM:
Hi Bore,
Thanks......
