mozes - Tuesday, December 25, 2012 3:55 AM:
Hi all I have one AML query with two different results.
I am interested in the related_id Item.
string itemType = item.getType();
string itemId = item.getID();
string amlStr = string.Format(
"<AML><Item type='{0}' action='get'><id>{1}</id></Item></AML>", itemType,itemId);
Item resultItem = inn.applyAML(amlStr);
result from method:
itemFull ==
<SOAP-ENV:Body>
<Result>
<Item type="cof_Assignment" typeId="..." id="...">
<related_id is_null="0" />
</Result>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
when I use the same qury in Nash or AML-STudio I get the right required result:
<SOAP-ENV:Body>
<Result>
<related_id keyed_name="111" type="cof_affected Item">
<Item type="Document" typeId="B88C14B99EF449828C5D926E39EE8B89" id="1190CB9BF0F547239BE4C4231A44FCE3">
<classification>Beheerd</classification>
</related_id>
</Result>
</SOAP-ENV:Body>
I also tried the attributes levels='4' and related_expand='1', I even tried to use item.apply() all with the same result.
The query used in the code always gave the same result for related_id.
I wounder if someone has an Idea how to solve this I need the related_id in the method I wrote.
Mozes
mozes - Wednesday, January 2, 2013 4:26 AM:
Hi All,
I wish you all happy new year.
The problem seemed to be the permission for Aras PLM on that affected Item.
I solved this by adding Aras PLM to a group with the right permissions.
(tnaks to Sean Coleman)
