DEVELOPERS FORUM - Setting data_source attribute of new properties of type Item causes error
Roller - Wednesday, January 9, 2013 8:55 AM:
When creating new properties of new item types i get error messages when i try to set the data_source attribute on properties of type Item or List. The required data_source item type is defined in the AML code before.
Simplified example:
<AML>
    <Item type="ItemType" action="add">
        <name>pc_Test1</name>
        <name>pc_Test2</name>
        <Relationships>
            <Item type="Property" action="add">
                <data_type>Item</data_type>
                <name>testproperty</name>
                <data_source>pc_Test1</data_source>
        </Relationships>
</AML>
Result:
<faultstring>"pc_Test1" is not a valid id</faultstring>
It looks like the previously defined ItemType of pc_Test1 cannot be set as data_source for the property testproperty.
asha_gholve - Friday, January 11, 2013 7:25 AM:
data_source is a ID and not a name,
It should be the ID of pc_Test1 Item type and not name
Asha
Roller - Tuesday, January 22, 2013 3:59 AM:
Hi Asha,
with the ID it works.
Bernd
