DEVELOPERS FORUM - Limiting files returned to released versions only
PlasmaTek - Wednesday, January 16, 2013 3:34 AM:
I am currently listing out files from Aras using the .Net API. However, I seem unable to limit the returned files to only the files that are released. I seem to get every iteration of the file. Could anyone assist?
Example code used:
String par = "CC217ECFAF0E45BB80D1CE570DD54877";
String dft = "A6F4974401834C56880B6A732D33A0AF";
String asm = "B1F21B3CCF4F44B6960B8A38AECE4E69";
Aras.IOM.HttpServerConnection MyConnection;
Aras.IOM.Innovator MyInnovator;
MyConnection = Aras.IOM.IomFactory.CreateHttpServerConnection("myserver/.../InnovatorServer.aspx", "Production", "user", "pass");
Aras.IOM.Item login_result = MyConnection.Login();
if (login_result.isError())
    Console.WriteLine(login_result.getErrorDetail(), EventLogEntryType.Error);
MyInnovator = new Aras.IOM.Innovator(MyConnection);
String filetypeIds = par + "," + dft + "," + asm;
Aras.IOM.Item qryItem = MyInnovator.newItem("File", "get");
qryItem.setAttribute("select", "id,keyed_name,modified_on,item_number,filename,file_type,state,is_released");
qryItem.setProperty("file_type", filetypeIds);
//Released, In Change"- highest revision of same file current_state
//qryItem.setPropertyCondition("state", "Released,In Change");
qryItem.setPropertyCondition("file_type", "in");
Aras.IOM.Item results = qryItem.apply();
qryItem = results.getItemsByXPath("//Item[@type='File']");
//Aras.IOM.Item item = results.getItemByIndex(0);
int counter = 0;
for (int i = 0; i < qryItem.getItemCount(); i++)
    Aras.IOM.Item item = results.getItemByIndex(i);
    if (item.getType().Equals("File"))
        String is_released = item.getProperty("is_released").ToString();
        if ((is_released != null) && (is_released.Equals("1")))
Many thanks
Phil - Thursday, January 17, 2013 3:19 PM:
Without getting too much into it...I find that sometimes instead of using the IOM, it is more reliable to use AML. For example..your section of code that is written this way:
I would change it to this :
string strAML = "<AML><Item action='get' type='file' select='id,keyed_name,modified_on,item_number,filename,file_type,state,is_released'>" +
                           "<file_type condition='in'>" + filetypeIds + "</file_type></Item></AML>";
Item result = MyInnovator.applyAML(strAML);
That should get it done for you.
PlasmaTek - Monday, January 21, 2013 5:50 AM:
Hi Phil
Many thanks for taking the time to answer my question. I'm still getting the same result though. ARAS just gives me all the files and the "is_released" property is reported as 1 for every file. I cannot seem to weed out only the geniuine released versions.
Colin
vasant - Monday, January 21, 2013 7:00 AM:
Hello Colin,
You can code as per below sample:
qryItem.setProperty("is_current", "1");
Thanks-Vasant
PlasmaTek - Monday, January 21, 2013 7:10 AM:
Hi Vassant
No go I'm afraid, every single file is still returned.
vasant - Monday, January 21, 2013 7:37 AM:
Hi Colin,
Actually file Lifecycle is Default LC, which has only one state "Released". So every file is Released for you.
If you wants to get files which are used under "Document File" then Aras is creating versions of file. And code of last post will gives you latest file.
But if you wants to get the latest released file used as native_file in CAD then try with following code:
Aras.IOM.Item qryItem = MyInnovator.newItem("CAD", "get");
qryItem.setAttribute("select", "id,keyed_name,modified_on,item_number,native_file");
qryItem.setProperty("name", "Test CAD");
Thanks-Vasant
