DEVELOPERS FORUM - Relate a created Item to an Item type as a relatedItem on saving the Item.
meenu - Monday, January 21, 2013 3:20 AM:
     I have an Itemtype and a relationship to the Itemtype ,Document as the related Item. Now what I' m doing is without using 'create' or 'pick ' options, I' m trying to relate the documents(At the time of creation) to my Item type by calling a method on OnAfterAdd.
The code I' m using is:
Dim inn As innovator = Me.getInnovator()
Dim dept As String = Me.getPropertyAttribute("team_id","keyed_name")
If dept="Design Engineering" Then
Dim rel_item As Item = Me.newItem()
   rel_item.loadAML("<Item type='Dept' action='get' Select ='name'>"+
                        "<name Condition='like'>Design Engineering</name>"+
                        "<Relationships>"+
                        "<Item type='DeptDocs' action='add'><related_id><Item type='Document'   action='get' select='name'> <name Condition ='like'>Des*<Item></related_id> </Item>"+
                        "</Relationships>"+
                        "</Item>"" )
Dim result As Item = rel_item.Apply()
End If
Here on save of a document, based on the condition I' m trying to relate this document to the Item type' s  relationship(As per the conditions) as  a relatedItem.
But this code is doing nothing. Anything I missed ? Please help me .
Thank you/ M.K
vasant - Monday, January 21, 2013 6:07 AM:
Hi Mk,
Code as mentioned below:
   rel_item.loadAML("<Item type='Dept' action='edit' where="[Dept].name='Design Engineering'">"+
                                "<name>Design Engineering</name>"+
                        "<Relationships>"+
                                     "<Item type='DeptDocs' action='add'>"+
                                           "<related_id>"+
                                                "<Item type='Document' action='get' select='name'><name condition ='like'>Des*<Item>"+
                                           "</related_id>"+
                                     "</Item>"+
                        "</Relationships>"+
                    "</Item>")
Dim result As Item = rel_item.apply()
End If
Thanks & Regards,
Vasant Padhiyar
meenu - Tuesday, January 22, 2013 12:52 AM:
Thank you Vasant,
Syntax of 'where' clause is creating problems.
And, can I add multiple related items at a time saying like: <name condition ='like'> *doc* </name>.  Will it add more than one related Item?
Thanks for your help.
M.K
