SUPPORT Q&A - Error: The workflow you are attempting to use is not the Allowed Workflows for this item
amiao - Tuesday, February 5, 2013 2:16 AM:
I defined an ItemType MyBom and put it under the relationship of MyPart.When I create a instance of MyPart and select the MyBom Tab, system raise an error message "The workflow you are attempting to use is not the Allowed Workflows for this item".
PS:MyBom's workflow has been delete, so it has not workflow.
amiao
Eric Domke - Wednesday, April 3, 2013 10:33 PM:
Is something else trying to trigger the creation of a workflow on either MyPart or MyBom (e.g. a life cycle state)?  Any workflow you try to instantiate must be associated with the item type as an allowed workflow.  If you don't want it to start by default, then leave the "default" check box unchecked.
