DEVELOPERS FORUM - How to get next possible Lifecacle State with ARAS API ?
JensRollenmueller - Wednesday, February 27, 2013 8:28 AM:
Hello Community,
how can I get the next possible lifecycle states of an Aras Item using API ? My problem is that I will get all next states and not only the "allowed" - there must be an identity of the current user.
I found no API which returns a List of assigned Identities.
// Returnvalue
List<string> nextLifecycleStates = new List<string>();
// Ermitteln des Aras-Items zum PLM Object
Innovator Inno = this.getInnovator();
// read the current state of my item
string currentState = this.getProperty("current_state");
// read the transformations
Item transitionItem = Inno.newItem("Life Cycle Transition", "get");
transitionItem.setProperty("from_state", currentState);
Item transitionItems = transitionItem.apply();
if (!transitionItems.isError())
 for (int iCurrentItem = 0; iCurrentItem < transitionItems.getItemCount(); iCurrentItem++)
  Item currentItem = transitionItems.getItemByIndex(iCurrentItem);
  // Get the "To-State Item"
  string toStateItemID = currentItem.getProperty("to_state");
  Item toStateItem = Inno.getItemById("Life Cycle State", toStateItemID);
  // Add to result
  if(!nextLifecycleStates.Contains(toStateItem.getProperty("name","")))
   nextLifecycleStates.Add(toStateItem.getProperty("name",""));
// Returnvalue
return nextLifecycleStates;
PeterSchroer - Wednesday, February 27, 2013 8:41 AM:
Hello Jens,   I do not remember the answer to either question (how to get allowed next LC states,  or   how to get Identity List), but I have done both in the past,  so I know it is possible.    I can tell you first how I find the answer.     The standard client has a dialog which somehow shows the actual allowed next LifeCycle states for the selected item and for the current user.    Normally I will look in the code of the client to answer most of my own questions.    Sometimes you will see several calls with logic in JS,  other times you will see 1 call to the server using a special method name.      The client JS libraries are where I find the best approaches to solving ptoblems.
--peter
JensRollenmueller - Tuesday, March 12, 2013 1:34 PM:
Hello Thanks,
I found it thanks -
<Item type="Part" id="3A76505FA2E347D89C96F30A12E2DDB9" action="getItemNextStates" />
// Jens
