SUPPORT Q&A - SSL/TLS error
sebwouaib - Wednesday, March 6, 2013 10:52 AM:
I have configured a HTTPS innovator server 9.3.0 SP6 : https://innovator.utbm.fr
with a trusted SSL certificate but when I try to upload a file I have the following error :
CloseInnovatorSession failed: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="http://www.aras.com/InnovatorFault"><faultcode>SOAP-ENV:Server</faultcode><faultstring>CloseInnovatorSession failed: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.</faultstring><detail><af:legacy_detail>CloseInnovatorSession failed: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.</af:legacy_detail><af:legacy_faultactor/></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
Is someone have an idea where could be the problem ?
Thanks in advance.
Sébastien Chevriau
