DEVELOPERS FORUM - how do i convert string to int in Server Side Method c#
Pankaj Thakur - Monday, April 15, 2013 2:30 AM:
Hello Community,
    I want to convert a value from string to int.
but when I convert it it shows an error that "Cannot  implicitly convert type 'Aras.IOM.Item' to 'int'  "
I also Try Convert.ToInt32(); & Convert.ToInt64();
If any one have any idea how to convert into int or how to fetch value into int then please  Help me  .
The value which i fetch into string is also integer type.
Thanks & Regards
Pankaj Thakur
zahar - Monday, April 15, 2013 3:53 AM:
Can you post the code? From the error i can see that you trying to convert to value but Item. Possible that you used getItemProperty("attr_name").ToInt() ????
if so you need to use
int intVal;
if (int.TryParse(.getProperty("attr_name"), out intVal) {
// do something if managed to convert
} else {
//do something if not
Rahul. - Monday, April 15, 2013 8:04 AM:
Hello Pankaj,
Use this - Convert.ToDecimal(this.getProperty("property_name"))
Hope this helps
Rahul Dixit
Pankaj Thakur - Wednesday, April 17, 2013 4:31 AM:
Hello Rahul Sir and Zahar Sir,
    Thank you . its Working.
Thanks & Regards
Pankaj Thakur
