SUPPORT Q&A - Client xml error new install
pkoehrer - Tuesday, April 23, 2013 11:38 PM:
Hello all, I have installed and configured a few times over innovator trial build 9.3.0.5663, I have it installed on server 2008r2 with sql 2012, another instance on Home server 2011 with sql express.  On the home server I am able to login via the localhost address in compatibility mode, when i attempt to access the system from my laptop I get " Error loading 192.168.1.137/.../ui_resources.xml"  This same error also occurs on the 1st setup either connect via the localhost on the server or remotely.  I have followed all install guides along with allowing all features of the trusted sites config, ran the .net config alas no luck.  I shuffled theough the c drive and checked this particular file which is present and properly formatted and am now out of ideas.  Any help would be greatly appreciated!!! trying to get this configured for a board meeting presentation in a week so far it is not going well.
Thank you!!
gks by TSI - Thursday, April 25, 2013 2:36 AM:
Are you using Internet Explorer 10?
This is a typical error when using IE10. IE10 is rolled out automaticaly for win7 users.
