DEVELOPERS FORUM - New Action , works similar to Check-in
Vardhan - Tuesday, April 30, 2013 2:09 AM:
I have created a new Action for my ItemType to replace the old file with new  file, which should work similar to Check-in action of the Documents.   Please help me with some sample code how Check in works.
Thank you, Vardh.
newcomer - Tuesday, April 30, 2013 4:38 AM:
Example from the developer docu:
var itm = this.newItem("File", "get");
itm.setAttribute("where", "[file].filename='customers.txt'");
itm.setAttribute("select", "id");
itm = itm.apply();
//item needs to be locked to attach file
itm.setAction("lock");
itm.attachPhysicalFile("c:\customers.txt");
itm = itm.apply();
//now save the changes to File Item
itm.setAction("update");
itm = itm.apply();
return itm;
Vardhan - Tuesday, April 30, 2013 6:25 AM:
Thank you,  I have tried this already, this is just locking the file not updating the file
But I' m trying to do both the actions Lock and replacing the file with new one at a time.
Vardhan - Tuesday, May 14, 2013 4:25 AM:
The example code is not replacing the file with new one. It is just locking the file related to my Item type. The code I am using is(VB):
Dim rel_files As Item  = Me.newItem("Tooling Files","get")
rel_files.setProperty("source_id",Me.getID())
rel_files = rel_files.apply()
Dim results As Item = rel_files.getItemsByXPath("//Item[@type='File']")
Dim cnt As Integer = results.getItemCount() - 1
 Dim i As Integer
  For i = 0 To cnt
    Dim file_item As Item = results.getItemByIndex(i)
     file_item.setAction("lock")
     file_item.attachPhysicalFile("D:\2.txt")
     file_item = file_item.Apply()
     file_item.setAction("update")
     Next i
Return Me
Any changes to the code required? Please help me.
