ergr - Tuesday, May 14, 2013 9:18 AM:
I have a button on field and a method added as Field Event. OnFormLoad the button will be in disable mode. Fill the fields and save the Item, on save the button should get enabled. How can I do this against 'Save' action of the Item?
Because the method pulls some information from the Item, before save the method will not work. So, I' m trying to keep the button in disable mode till the Item gets saved. Please help me to do this.
Thank you.
zahar - Tuesday, May 14, 2013 3:18 PM:
You can create onPopulateForm js method that will check state of the item and if saved will enable the button
