Alexandr - Wednesday, June 4, 2008 12:00 PM:
I downloaded v9.0 installation package on June 4, 2008. During the installation I got two Error messages:
- Error 1001. Index was outside the bounds of the array.
- Error 1001.An exception occurred during the Rollback phase of the installation. This exception will be ignored and the rollback will continue. However, the machine might not fully revert to its initial state after the rollback is complete. --> Index was outside the bounds of the array.
Here is installation log:
Installing assembly 'c:program filesarasinnovatorinstallinstallinnovatorclass.dll'.
Affected parameters are:
originaldatabase = C: empArasInnovationInnovatorSetup.msi
assemblypath = c:program filesarasinnovatorinstallinstallinnovatorclass.dll
innovatorpath = C:Program FilesArasInnovator
installtype = notransaction
logfile = c:program filesarasinnovatorinstallinstallinnovatorclass.InstallLog
action = install
installparams = FeaturesInstalled={CommonFiles,_1_Innovator_Files,_2_Vault_Files,_3_DB_Files}$UPGRADEORINSTALL={1}$configureDotNetPolicy={1}$webAlias={InnovatorServer}$productCode={{58E55300-BC1B-426A-AC0B-18782BC291CD}}$productVersion={9.0.1}$DbList={id:InnovatorSolutions;database:InnovatorSolutions;server:(local);uid:innovator;pwd:ej&4eRRT$#nj;se;|}$UILevel={5}$IIS_VERSION={#6}
Rolling back assembly 'c:program filesarasinnovatorinstallinstallinnovatorclass.dll'.
action = rollback
An exception occurred during the Rollback phase of the Aras.Installation.InstallInnovatorClass.InstallInnovatorClass installer.
System.IndexOutOfRangeException: Index was outside the bounds of the array.
OS is Windows 2003. It has .Net Frameworks 1.0, 1.1, 2.0.
Any advise would be appreciated. Thank you.
Sean - Monday, October 13, 2008 5:53 PM:
Alexandr,
There is currently a known bug with the installer with regards to using a "$" in your password. There are two possible workarounds to this problem.
The first one is simple, just remove the "$" from your secure password.
If the first option is not a valid workaround you can install using configure only. Please refer to the Aras Innovator Installation Guide for more details. After you install using this method you will have to restore the database following the instructions in the document How to restore a database from bak;. After you have succesfull restored the database you will have to edit the InnovatorServerConfig.xml located in the root of your installation. You will have to set the database name, login, and password according to your needs.
Hope this helps.
Sean
