thopkins - Wednesday, May 22, 2013 10:37 AM:
Thanks!
Brian - Wednesday, May 22, 2013 8:16 PM:
I think this might be caused by IIS settings.
See this link: http://www.arascorp.comhttp://www.aras.com/Community/forums/p/348/7705.aspx to the same question some time ago.
It looks like it was solved by adding the Web Server role to IIS.
Hope this helps,
chipchop40 - Friday, June 7, 2013 4:51 PM:
THopkins,
I am having the same issue. I have gone over the install, IIS and .Net
Did this issue get resoved? I sure could use a hand up.
Thank you
thopkins - Wednesday, June 19, 2013 9:05 AM:
chipchop40,
Sorry I never was able to get the install to work properly. Our company is also considering other products in the market.
Thopkins
Jennifer - Wednesday, June 19, 2013 9:20 AM:
Hi THopkins and ChipChop -
This error usually comes down to client settings. Verify msxml4 sp3, .net 3.5 SP1 are installed on the client.
Then double check IE settings, if its IE9 you must have compatibility view enabled with 9.3.0.
Best,
Jennifer
