parepalli - Tuesday, June 4, 2013 2:24 AM:
When I run the a method on client side as a pre/post method in a Workflow Map Path, I am getting a message "The method type(JavaScript) for (name of method) is not currently supported". Can any body please tell me if this is a problem with the Aras or I am missing some thing?
Thanks in advance.
vasant - Tuesday, June 4, 2013 3:45 AM:
Hi Parepali,
You can't write Client Side (Javascript) code on pre/post method in a Workflow Map Path. You can only write Server Side Code(C#, VB) here.
Thanks- Vasant
parepalli - Friday, June 14, 2013 1:52 AM:
thank you so much for the reply.
