DEVELOPERS FORUM - The Property name must be common to all source
Shantha - Tuesday, June 18, 2013 5:39 AM:
I'm trying to add ECR in "Poly Source" tab  but i cant able to do. Aras throwing error message as "The Property name must be common to all source or the property name has inapproriate data type." In which i double check the item_number Property field but its correct about which property it means?
Thanks.
Eric Domke - Thursday, June 27, 2013 1:01 PM:
With poly items, each property called out in the poly item must exist in all of the item types added to it and have the same type in all of the item types.  I don't recall offhand if the length of string properties matters as well.  The message is saying that the poly item in question calls out some property in its properties tab which is not present in the ECR, or it is present, but of a different type.
