ergr - Thursday, July 4, 2013 3:18 AM:
What is the easier way to get the source item' s property value on the related item?
For ex: ItemTpye1(source item) has a field and a relationship, where Itemtype2 is the related item. Itemtype2 has a field. I can only 'Create Related' from Source Item. When I create a related item and save then its field should get the same value what source item' s field have.
For this I have created a ServerEvent and added under Itemtype2 with OnBeforeAdd. The way I tried is, I added a property on Relationship Itemtype data typed as Foreign pointing to SourceItem' s property. And I' m setting this property value to the related item's field.
Dim id As String = Me.getID()
Dim relitem As Item = inn.newItem("RelationshipItem","get")
relitem.setAttribute("where","[RelationshipItem].related_id = '"+id+"' ")
Dim res As Item = relitem.Apply()
Me.setProperty("stage_id",res.getProperty("test",""))
OnBeforeAdd it says 'Not A single Item' , OnBeforeUpdate it is working. Where I need to save the Source Item first to add the relationship and two times save of related item.
Is there any other best way of doing this?
Thank You
zahar - Thursday, July 4, 2013 4:24 PM:
You cab set onAfterAddonAfterUpdate on Relationship and write following code:
Dim source as Item = Me.getPropertyItem("source_id")
Dim related as Item = Me.getRelatedItem()
Dim update as Item = inn.newItem(related.getType(), "merge")
update.setAttribute("version", 0) //if your item type is versionable
update.setAttribute("serverMethod", 0) //if you prefer not execute any servermethods on related item update
update.setProperty("stage_id",source.getProperty("test",""))
Dim result Item = update.apply()
