DEVELOPERS FORUM - Not able to assign a string value to the string type attributes of a PR ITEM Type
jacobandrews - Monday, July 15, 2013 2:52 AM:
string sattr1 = "PR-10005"
string sattr3 = "finalchange"
 Item pr1 = MyInnovator.newItem("PR", "add");
                        bRes = pr1.isError();
                        pr1.setProperty("item_number", sattr1);
                        pr1.setProperty("title", sattr3); /// Without this line of code , the PR gets created...
                        pr1.apply();
Please suggest what is wrong in the method of setting the property attribute.
Even if I use pr1.setPropertyAttribute("String","title",sattr3); it does not work
zahar - Monday, July 15, 2013 11:16 AM:
try to return error from  pr1.apply() when you trying to set title
Brian - Monday, July 15, 2013 8:51 PM:
Hi Jacob,
Not sure what is wrong with your code.
It works for me.
This code executed as an action creates the PR with the "finalchange" title as expected.
string sattr1 = "PR-10005";
string sattr3 = "finalchange";
Item pr1 = inn.newItem("PR", "add");
pr1.setProperty("item_number",sattr1);
pr1.setProperty("title",sattr3);
pr1 = pr1.apply();
if ( pr1.isError() ){
return inn.newError(pr1.getErrorString());
return this;
I suggest using the "pr1 = pr1.apply();" syntax then you can check and return the error if there is one.
Hope this helps.
jacobandrews - Wednesday, July 17, 2013 4:42 AM:
Thanks for the reply.
its displays the error "the PR already exists"...
Its displays the same message even if a PR no that does not exist id given as input for creation of the PR.
jacobandrews - Friday, July 19, 2013 2:25 AM:
Hi Brian,
I changed the code like this... Its now works in this fashion...
Now I am setting the affected item attribute at the end ... First I set all the string values....
                        pr1.setProperty("title", "tushar");
                        pr1.setProperty("environment", "tushar machine ssghosig ");
                        pr1.setProperty("events", "seq121212121");
                        pr1.setProperty("description", " desc1  desc sldjflksgflasdnflsanlsnfd slfnlsfnslnf descropr[trtkn");
                        pr1.setProperty("verification", " verification is required for the below nedds");
                        // Set the Affected Item property by getting the tag of the item and attaching it to the item
                        Item qryItem = MyInnovator.newItem("Part", "get");
                        qryItem.setAttribute("select", "item_number");
                        qryItem.setProperty("item_number", sattr2);
                        qryItem.setPropertyCondition("type", "eq");
                        Item results = qryItem.apply();
                        Item pt1 = results.getItemByIndex(0);
                        pr1.setPropertyItem("affected_item", pt1);
                        Item check1 = pr1.apply();
