tpd15 - Monday, July 29, 2013 9:18 PM:
I'm a new user, trying to get my first install of Aras 9.3 up and running. I have installed it on a laptop to try it out, but can't seem to get past the .NET security, as a lot of previous posts here seem to also have run into.
When I try to hit 35emba2013l811/innovatorserver I get the failure message:
Setting security for .NET 2.0 ...
WARNING: It seems like a group with the membership URL similar to
"localhost/.../" already exists:
1.7. Url - localhost/.../*: FullTrust (Exclusive LevelFinal)
NOTE: creation of multiple groups with the same name or the same
membership URL can cause problems when running Innovator
Removing existing group shown above and create a new
group with membership URL "localhost/.../" ....
Delete old group with membership URL "localhost/.../" ...
Microsoft (R) .NET Framework CasPol 2.0.50727.5420
Copyright (c) Microsoft Corporation. All rights reserved.
Removed code group from the Machine level.
Success
Create new group with name "localhost/innovatorserver" ...
Added union code group with "-url" membership condition to the Machine level.
Success
Brian - Tuesday, July 30, 2013 8:38 PM:
Hi Toby,
This can sometimes be a frustrating thing.
This error is only related to the .Net security settings and the Trusted Sites in IE.
So just to be sure:
sdns.exe must be copied to a local directory on the machine it is to be run on.
sdns.exe should be run as Administrator
Enter the URL: localhost/innovatorserver in the sdns.exe box and hit OK.
Now go to IE | Tools | Internet Options | Security tab | Trusted Sites -> Sites button.
Add localhost to the trusted sites. Ensure that the "require server verification...." is unchecked.
Also ensure that you are using IE9 32 bit not 64 bit.
Hope this helps,
tpd15 - Friday, August 2, 2013 10:32 AM:
Hi Brian,
Thanks for the reply. It turns out that I had 3 problems. I was able to spend a couple of hours on the phone with a super-user, who very generously helped me work through my issues.
The problem that was demonstrated in my post above was caused by me using 64-bit IE9. As soon as I switched to 32-bit IE9, that issue went away. (I see that Innovator 9.4 is now available; maybe it works with 64-bit IE and this problem is moot.)
I had previously set-up IE according to the document on Aras' website, but nowhere in it does it say you shouldn't use 64-bit IE. That would be helpful info for them to have in there, right?
The other problems I had were that when I installed Innovator, I had specified my own password in the "Database Login Options" section. This part of the install process is described on page 27 & 28 of the install guide, where I read it to mean that I had to come up with a password of my own. Apparently, though, I was supposed to use 'innovator'.
The final problem could have been related to not using the correct password, but when installed, there were no Aras tables inside SQL Server. The folder structure was there, but it was empty -- so when I did resolve issue #1, and was able to get to the log-in screen, there was nothing to connect to.
All resolved now, and hopefully people who come along afterwards might be able to learn something from this post, as I saw numerous other posts with the same issue, and none of those seem to have been resolved.
Toby.
