dalewill - Tuesday, August 6, 2013 2:50 PM:
Everyone:
I'm working on my first method. A small piece of code to return a top assembly part #.
Item qryItem = this.newItem("A_CN", "get");
qryItem.setAttribute("select", "top_assy_pn");
qryItem.setProperty("id", "XXXXXXXXXXXXXXX");
Item results = qryItem.apply();
string pn = results.getProperty("top_assy_pn");
results.setProperty("tap", pn);
When I 'Run Server Method', the return data is:
<top_assy_pn keyed_name="11093-8" type="Part">6B44F561DD104C41AF08A73C7D3865A3</top_assy_pn> <tap>6B44F561DD104C41AF08A73C7D3865A3</tap> </Item>
The data is correct, what I want to get with the results.getProperty("top_assy_pn") statement is the keyed_name value of 11093-8, not the GUID. I've tried several things with no luck. How can I pull that keyed_name value out?
Sincerely,
Dale Williams
zahar - Tuesday, August 6, 2013 4:10 PM:
You can change your code to do what you expect:
qryItem.setAttribute("select", "top_assy_pn(keyed_name)");
Item pn = results.getPropertyItem("top_assy_pn");
string keyed_name = pn.getProperty("keyed_name");
results.setProperty("tap", keyed_name);
dalewill - Tuesday, August 6, 2013 4:17 PM:
Zahar:
Thanks for the help. That worked perfectly.
Sincerely,
Dale
