akshay kadam - Tuesday, August 6, 2013 3:27 AM:
i want to add a new life cycle state and in that state user can update the document but the revision of the document should not be changed after updating. So what i can do for this, please help me i am beginner to Aras.
Thanks in advance.
[email protected] - Monday, August 12, 2013 4:30 PM:
Hello Akshay,
you will have a lot of different options, e.g.:
- using manual versioning within your item => result: end user has to use context menu "version" before creating a new version.
- defining lifecycle state as "not released" => result: system will change generation - not major.rev
Please ready configuring guide to get and understand these options.
Regards, Jens
NTT DATA Germany
akshay kadam - Friday, August 23, 2013 5:51 AM:
HI Jens,
Thanks for your help.
I have some issue related to search dialog. I am showing a search dialog from code and i want to get selected result. But i am unable to get hat selected file object, please help me if you can. Below is the code that i have use for populating search box,
var param = { aras: top.aras, itemtypeName: 'File', multiselect: false };
var dlgRes = showModalDialog('searchDialog.html', param, 'dialogHeight:450px; dialogWidth:700px; status:0; help:0; resizable:1;');
if(!dlgRes)
return;
Thanks.
[email protected] - Monday, August 26, 2013 3:15 AM:
My opinion is that you shouls have the selected item ob dlgRes.
Have you checked this?
akshay kadam - Monday, August 26, 2013 3:42 AM:
Thank you Jens,
Yes i have checked that dlgRes and selected item is in dlgRes.
Thanks.
[email protected] - Thursday, August 29, 2013 4:41 AM:
If you like to allow multiselect, dlgRes will contain a ItemCollection.
Therefore you have to check: if(dlgREs.isCollection) to be sure.
Jens Rollenmüller, NTT DATA Germany
