SUPPORT Q&A - New custom property(only for a sub class for part) not showing up in "Unused Properties" in the Part form
hari.varadahrajan - Tuesday, August 13, 2013 6:05 AM:
Dear all,
Iam using ARAS innovator 9.3, and exploring the features.
I created a sub class in part called "CustomPart".
I created a property called Location that is applicable only to this custom part , done through specifying
the "Class Path"  as "Custompart" in the property.
Now in order to make this appear in the form, I went to the Part form and expected the property "Location" to
appear in the "Unused Properties". Strangely its not showing up there.
It worked perfectly a week back.
Please help!
Hari
[email protected] - Tuesday, August 13, 2013 10:03 AM:
Hari,
I had same problem some days ago and used a workaround:
1) Delete Custom Class from Item property
2) Add Property to form and save form (it will be shown within unused properties)
3) Redefine Custom Class within Item property
Sorry it is only a workaround - but for me it worked fine. Hopefully it will be fixed by Aras Support - so please send issue to [email protected] => They have to fix this issue.
Regards, Jens
NTT DATA Germany
hari.varadahrajan - Wednesday, August 14, 2013 6:16 AM:
Hi Mr.Rollenmuller,
Thank you for the response. The problem is technically now resolved as per your work around , but there is another problem due to this.
I get the following message in the UI  - My custom Part is "INDPart" created as subclass in Part. That is displayed superimposed on the custom property (here i created
a custom property "Supplier part no" applicable only to INDpart subtype / sub class)
"Resource with key="'class_spec_field.Part_INDPart'" is not found".
However, Iam able to enter the values for the custom property in the UI and can save the part.
But I dont like the message in the UI. Did you also have this problem?
I have screen shots also, but unable to attach in this post.
Thanks & Regards
hari.varadahrajan - Wednesday, August 14, 2013 7:21 AM:
There is a solution to the error message issue in another thread.
http://arascorp.comhttp://www.aras.com/Community/forums/p/2288/7110.aspx
Thanks for your valuable help!
have a nice day
Warm Regards
Hari
hari.varadahrajan - Wednesday, August 14, 2013 8:14 AM:
Hi Jens,
It did not work for me. But the
original message is gone.
I have added this line in that XML file.
Now in the label for the custom property on top of the field, it is just displaying the text in blue font  "INDPart Properties".
<resource key="class_spec_field.Part_INDPart" value="INDPart Properties"/>
Iam sure that Iam missing something. please let me know.
Hari
