ramyasri - Sunday, August 18, 2013 4:09 AM:
I have one ItemType called Scope, that instances(item) is used in many Projects. But i need the latest Project name should display in my Scope item grid.
Tell me how to approach, either relationship grid event or any easiest way is their to get.
Thanks in advance! Its Urgent.
[email protected] - Monday, August 19, 2013 2:53 AM:
I think scenario 1) could be the best.
1) It should be solved when using "Float" for the rleation => then it will be automatically changed to the newest Version of your Item "Project"
2) Otherwise you can solve the Problem programmatically"
Create a "Method" - on after create of a "Project", which will change the Projects within all relations (AML / SQL - depending how you would like to do rights management)
Be aware that you have to design some kind of "architecture" for the solution 2).
Hopefully I understand the problem - otherwise please send more details.
Jens Rollenmüller
NTT DATA Germany
