aprilolivia - Tuesday, August 27, 2013 4:29 PM:
Good day,
I have recently installed Aras Innovator 9.4 on Windows 2008R2 server. I can log into the client on the server.
On a separate computer on the network running Windows 7 and IE10 I have followed all the procedures for setting up client. .Net 4 and 4.5 are installed. I get error trying to access:
Aras Innovator client has failed to initialize.
Hosting .net controls in Internet Explorer is disabled.
I have been all over this forum looking and trying tricks for ie10 and .net 4.5... no luck.
Can someone help?
Thank you.
April
junebong - Tuesday, August 27, 2013 10:32 PM:
Hi April,
I hope this can help you.
http://msdn.microsoft.com/en-us/library/hh367887.aspx
Setting the EnableIEHosting value of the registry subkey
HKLM/SOFTWARE/MICROSOFT/.NETFramework to 1 for x86 systems and for 32-bit processes on x64 systems,
and by setting the EnableIEHosting value of the registry subkey
HKLM/SOFTWARE/Wow6432Node/.NETFramework to 1 for 64-bit processes on x64 systems.
June
aprilolivia - Thursday, August 29, 2013 10:12 PM:
June,
Thank you for the timely reply. Sadly this did not help.
HKLM/SOFTWARE/MICROSOFT/.NETFramework EnableIEHosting was already set to 1
and HKLM/SOFTWARE/Wow6432Node/.NETFramework EnableIEHosting did not exist. I created it and set to 1.
No change in error when launching the aras client.
Any other ideas?
Thank you,
April
Tom C - Tuesday, September 3, 2013 7:30 AM:
Hi.
I have the same problem, only difference is that my client is running Win7 64-bit with IE8, and the server has .NET 4.0 installed.
I have also run the sdns utility to add the URL's (added both localhost and servername entries) + added the mentioned registry keys, but still no luck.
Would appreciate any suggestions.
Tom
Gorinich - Wednesday, October 9, 2013 3:53 AM:
I have the same issue, but with IE9 and .NET 4.0 installed. Any ideas?
Grinko Nastya - Tuesday, December 10, 2013 7:47 AM:
I had the same problem (IE 9.0.22, Net 4.5.1).
But June's advise have help me.
May be, you use wrong type of values when add keys to registry?
I have added and all work!
[HKEY_LOCAL_MACHINESOFTWAREMicrosoft.NETFramework]
"EnableIEHosting"=dword:00000001
[HKEY_LOCAL_MACHINESOFTWAREWow6432NodeMicrosoft.NETFramework]
Nastya
arnaud.chaussard - Monday, September 29, 2014 9:39 AM:
Hello !
The registry entries helped but I also had to disable IE protected mode in the Security tab (trusted, intranet, or other sites' category if needed...). At least it did the job for me... I hope it helps !
Arnaud
rajeshwar - Friday, October 31, 2014 1:50 AM:
Hi Nastya,
I am trying to resolve my hosting .net controls error as per your instructions, but it is not working .
Have any other idea?
thank you,
Rajeshwar
