jsnosal - Thursday, August 29, 2013 2:43 PM:
Our MCO process requires that we show all the affected items based on the parts that are affected. I'm wondering if the query I have below is possible? I would like to use this as a reverse grid look up within a tab. With the testing I have done so far I can't get it to work the way I want it to. Is there a different way I go about doing this? The main thing is I need to be able to export this as a report. Thank you for your help its greatly appreciated.
<Item type="Simple MCO" action="get" id="{@id}">
<Relationships>
<Item action="get" type="Simple MCO Part">
<related_id>
<Item type="Part" action="getItemWhereUsed"></Item>
</related_id>
</Relationships>
Eric Domke - Thursday, September 26, 2013 8:32 AM:
Would something like the following work?
<id condition="in">
(SELECT pb.SOURCE_ID
from innovator.PART_BOM pb
INNER join innovator.SIMPLE_MCO_PART smp
on smp.RELATED_ID = pb.RELATED_ID
where smp.SOURCE_ID = {@id})
</id>
zahar - Thursday, September 26, 2013 8:41 AM:
you need to move you sql to "where" atribute of Item
something like this:
<Item type="Part" action="get" where="[Part].id in (SELECT pb.SOURCE_ID
from [PART_BOM] INNER join [SIMPLE_MCO_PART]
on [SIMPLE_MCO_PART].RELATED_ID = [PART_BOM] .RELATED_ID
where [SIMPLE_MCO_PART].SOURCE_ID = {@id})" />
Eric Domke - Sunday, September 29, 2013 10:58 PM:
I have used both AML structures (SQL in the where attribute and SQL as an "in" condition) with equal success. In fact, of the two, I have probably used SQL as an "in" condition more frequently, but for no good reason.
AbhishekSrivastava - Friday, March 18, 2016 2:41 AM:
hello friends,
I want to populate value from sql db to Aras. So the scenario shown below:
I have a vendor Item Type and having 3 property,
1. Vendor Category, 2. Vendor Name , 3. NDA Status
I have Test Item Type and having again 3 property:
but when i select Vendor Category then Vendor name Sort and i need to select as per this NDA Status Shown and Auto selected.
So Is that Possible if yes then please share you experts solution.
Thanks In Advance
Abhishek Srivastava
