Vardhan - Wednesday, September 11, 2013 9:30 AM:
I have created an independent Form with html dropdown and I am calling this Form from an Action(item,client). HTML code in the Form I used is:
<script>
function Ok()
var doc = document.getElementById("select1");
var targetItem = doc.options[doc.selectedIndex].text;
//alert(targetItem);
close();
function cancel(){
close();
</script>
<html>
<body>
<select id="select1">
<option value="1">Item1</option>
<option value="2" selected="selected">Item2</option>
<option value="3">Item3</option>
</select>
<br/><br><br>
<button style="width:50px" onClick="Ok();">Ok</button>
<button style="width:50px" onClick="cancel();">Cancel</button>
</body>
</html>
And a method added to the Action to call this Form as dialog with code:
var formNd = top.aras.getItemByName("Form", "MyDialogTest", 0);
if (formNd)
var param = new Object();
param.title = "Select Item";
param.formId = formNd.getAttribute("id");
param.aras = top.aras;
var width = top.aras.getItemProperty(formNd, "width");
var height = top.aras.getItemProperty(formNd, "height");
var _type = showModalDialog("ShowFormAsADialog.html", param,
"dialogHeight:" + height + "px; dialogWidth:" + width + "px; " +
"status:0; help:0; resizable:0; scroll:0;");
//alert(_type);
if(_type == "Item1")
var _item_doc = inn.newItem("Document","add");
var result_doc = _item_doc.apply();
top.aras.uiShowItem("Document", result_doc.getID(), 'tab view', true);
else if(_type=="Item2")
/// add & show ItemType2
else
///add & show ItemType3
Based on the value selected from the Dialog I should add and display an Item. But var _type is always returning 'undefined' . How do I get the value selected in the form's dropdown.
Thank you.
zahar - Wednesday, September 11, 2013 9:46 AM:
in your OK button function use this:
document.parentWindow.setReturnValue(targetItem)
Vardhan - Friday, September 13, 2013 2:44 AM:
Worked! Thank you Zahar.
-Vardh
