xgecko - Wednesday, September 25, 2013 1:31 PM:
I am trying to run a NASH import. After logging in and entering the following in the XML window I get an error indicating that the root element is missing. I cannot find anything on this error suggesting how to resolve it.
Input:
<AML>
<Item type='Part' action='add'><item_number>104004</item_number><name>DO-160 Temperature & Altitude</name><description>DO-160 Temperature & Altitude;Test Spec;;</description></Item>
</AML>
Output:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="www.aras.com/.../faultcode><faultstring><![CDATA[Root element is missing.]]></faultstring><detail><af:legacy_detail><![CDATA[Root element is missing.]]></af:legacy_detail><af:exception message="Root element is missing." type="System.Xml.XmlException"/></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
mendenaresh1357 - Thursday, September 26, 2013 4:51 AM:
I think the Issue is with the special character '&'. Can you try replacing '&' with '&'.
Naresh Mende.
madmax33 - Friday, December 20, 2013 6:48 AM:
Hey,
I am getting the same error. did you find a solution?
Eric Domke - Thursday, September 26, 2013 8:18 AM:
Also, your attributes should use double quotes, not single quotes. Therefore, the AML should read:
<AML>
<Item type="Part" action="add">
<description>DO-160 Temperature & Altitude;TestSpec;;</description>
</AML>
xgecko - Friday, December 20, 2013 8:09 AM:
Yes. See the above thread. The quotes were my problem.
madmax33 - Thursday, December 26, 2013 5:22 AM:
Hi xgecko
Thanks for the prompt reply. I check the quotes and they are correct for me. I am still facing the problem.
Can you tell me which version are you using?
Regards
