APPLICATION - PRODUCT ENGINEERING - Multilevel BOM Report - Number of Level Limit
W_A_Watson_II - Wednesday, June 18, 2008 6:04 PM:
In the Multilevel BOM Report I've hit an issue with the Number of Level Limit.
Currently our US Product Structure Maximum level is 12 levels, while in Brazil we go as deep as 23.  I've built a 7 level Product Structure, and when I run the Multilevel BOM Report I loose the 7th level items off of the report.
Has anyone made a fexiable Multilevel BOM Report report that lets you select the number of levels to report on?
Will
SamsAn - Thursday, June 19, 2008 2:55 AM:
I fixed the problem for some customizations. You may touch me if the solution is required (contains several aml files, instructions, etc.).
[email protected] - Tuesday, June 29, 2010 7:02 AM:
Same way  I have same issue no. of Multilevel BOM.
While developing the data in the software I came across  two queries.
1. In the creation of BOM, when I am putting the data in the 'parts' the part no. when I  enter it will show' Part no  generation already exist'
Can any one show me how this error can be removed.?
2. Can anyone show me how should I prepare a BOM, which showing the Product with its parts and the BOM will preview forecasting of Material quantity?
Thanks.
Sachin
sama - Friday, May 21, 2010 2:28 AM:
SamsAn,
I am working towards achieving the same requirement. Please share your solution.
Sama
[email protected] - Tuesday, June 29, 2010 7:14 AM:
Thanks.
Sachin
SamsAn - Friday, May 21, 2010 9:14 AM:
Hi.
Unfortunately, currently i don't have any chance to provide a solution for this bug (i do not have access to the existing solution now, it will take pretty long time for me to reimplement the solution). So, i recommend these options:
1. Check the latest version of innovator (PLM Solution, see the report metadata and related server-side methods). Probably this version already contains the solution.
2. Contact aras for help.
Samsan.
RobMcAveney - Friday, May 21, 2010 9:44 AM:
See this post for an alternate report to use: http://www.aras.comhttp://www.aras.com/Community/forums/p/622/1824.aspx#1824
You can just remove the "Part Document" line in the query and the Type column in the XSLT if you don't want to see attached documents
