SUPPORT Q&A - Runtime Error - Server Error in '/InnovatorServer' Application
jadearas - Monday, October 7, 2013 12:08 AM:
I have installed ARAS v9.3. However when I click on the startup icon, I recieve an error message
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed.
Details: To enable the details of this specific error message to be viewable on the local server machine, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "RemoteOnly". To enable the details to be viewable on remote machines, please set "mode" to "Off".
<!-- Web.Config Configuration File -->
<configuration>
    <system.web>
        <customErrors mode="RemoteOnly"/>
    </system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
    <system.web>
        <customErrors mode="On" defaultRedirect="mycustompage.htm"/>
    </system.web>
</configuration>
Server Error in '/InnovatorServer' Application.
Runtime Error
I am actually using an old server to give aras innovator a trial.
Database = MS SQL Server 2005
Servers = MS. NET 3.5
O/S = MS Windows Server 2003 std edition
Appreciate if anyone can assist. Thank you
Gorinich - Wednesday, October 9, 2013 3:57 AM:
Hi, Jade
Try to check IIS Aras Application Pool .NET Framework settings.
