gummareddypura - Friday, December 13, 2013 1:29 AM:
Hello All,
I am trying to install requirements manager add-on package. i was unable to deploy package.
Can some one help me how to remove package definition or package.
Please find the log that has generated by import/export utility.
Set "Root" value for "Logon Allowed To" variable
Updating usb.solution.requirements to inprogress release status
****Import with merge option usb.solution.requirements****
Processing (add) id : EAB29654E2CD4D30B376957788198B40 keyed_name : Categories type : List
********** Start of reference checking ************
checking for Bad property
<Item type='ItemType' action='get' select='id'><name>List</name><Relationships><Item type='Property' action='get' select='name'/><Item type='RelationshipType' action='get' select='name'/></Relationships></Item>
was obtained from server
<Item type='ItemType' action='get' select='id'><name>Value</name><Relationships><Item type='Property' action='get' select='name'/><Item type='RelationshipType' action='get' select='name'/></Relationships></Item>
was obtained from cache
************* End of reference checking ************
Item successfully applied(add) id : EAB29654E2CD4D30B376957788198B40 keyed_name : Categories type : List
Adding item in packdefinition id EAB29654E2CD4D30B376957788198B40 type List
****Error message****
faultstring: Duplicate package element
faultdetail: The package 'usb.solution.requirements' already contains the PackageElement with id='EAB29654E2CD4D30B376957788198B40' but of different type: DB - type='List', group_id='70CA195417244964A6806AE9C081FD5F'; being imported - type='List', group_id='C355DB42195F4CA6BEF090D7103F5388'
faultcode: -2
Updating usb.solution.requirements to failed release status
Set "World" value for "Logon Allowed To" variable
