SUPPORT Q&A - Active Directory Integrated Authentication
blandry - Wednesday, July 2, 2008 4:12 PM:
Here is my InnovatorServerConfig:
<Innovator>
  <UI-Tailoring login_logo="../images/logos/innovator_splash.jpg" branding_img="../images/logos/banner_02.jpg" product_name="Aras Innovator" banner_url="../scripts/banner.aspx" banner_height="50" />
  <operating_parameter key="debug_log_flag" value="false" />
  <operating_parameter key="debug_log_limit" value="10000" />
  <operating_parameter key="debug_log_pretty" value="true" />
  <disabled_operating_parameter key="performance_logging" value="cpu" />
  <operating_parameter key="xslt_processor_debug" value="false" />
  <disabled_operating_parameter key="email_debug_option" value="file" />
  <License lic_type="Unlimited" lic_key="45yu7457456mn865m8587yyhghtryhw" />
  <Mail SMTPServer="queue" />
  <operating_parameter key="temp_folder" value="C:Program Files (x86)ArasInnovatorInnovatorServer emp" />
  <operating_parameter key="ServerMethodTempDir" value="C:Program Files (x86)ArasInnovatorInnovatorServerdll" />
  <operating_parameter key="debug_log_prefix" value="C:Program Files (x86)ArasInnovatorInnovatorServerLogs" />
  <DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="(local)" uid="innovator" pwd="{deleted}" dbType="SQL Server" />
  <DB-Connection id="Test1" database="Test1" server="(local)" uid="innovator" pwd="{deleted}" dbType="SQL Server" />
  <ClientConfig
   AssemblyName="Aras.LogonHooks.WindowsAuth"
   AssemblyNameType="partial"
   TypeName="Aras.LogonHooks.WindowsAuth" />
  <ClientLogon allowed_domain_names=".*"
               allowed_domain_users=".*"
               denied_domain_users="^admin$|^root$|^vadmin$|^PLM$"
               allowed_direct_users="^admin$|^root$"
               debugging_password="bypass1"
               shared_secret="randomrandom"
               empty_logon_user_allow_direct="false" />
</Innovator>
I have walked through page 14 and 15 of the Aras Innovator Authentication Setup, (Doc #: 9.0.105232008) and am hitting a wall.  I get the username showing up for the logged in user and the DB dropdown, but when I select the DB with the existing blandry user account it get the error message:
"Authentication failed for blandry"
Repeating steps 5 through 10 does not help.  I had changed allowed_domain_users=".+" to ".*" because it was saying that my user account was not allowed.
 I have 2 databases InnovatorSolutions and Test1, the user accounts are setup in Test1, but not in InnovatorSolutions.  Any ideas?
Brian
Bill - Wednesday, July 2, 2008 5:52 PM:
Try specifying the domain, as in the example.
becomes
<ClientLogon allowed_domain_names="^DOMAINNAMEHERE$"
-Bill
Bill - Wednesday, July 2, 2008 6:00 PM:
Also, please try
becomes
as in the example.
I prefer to start with getting this example working, and customizing from there.  As it has been a very reliable set of steps in the past.
-Bill
blandry - Thursday, July 3, 2008 9:28 AM:
I did change it to:
And for some reason did not get the denied domain user again on the user line, but I am still getting the "Authentication failed for blandry" error.
blandry - Thursday, July 3, 2008 9:29 AM:
I also changed the allowed domain users back to ".+" as well without success.
Brian
Bill - Thursday, July 3, 2008 12:50 PM:
You need to log in a Innovator Admin again, and re-run the "Reset Authentication Passwords" action again.
-Bill
blandry - Thursday, July 3, 2008 1:32 PM:
I've tried that 3 times since this morning.  Any idea what it could be hanging on?  I have blandry in Active Directory and in the Test1 database in Innovator.  I have the blandry account in Innovator enabled and have used the Reset Auth Passwords, so what could it be?
If it sees my user name properly on the login screen, what does it do beyond that?  Does it talk to Active Directory?  When I use the Reset Authntication Passwords I get this for a result:
admin: matched denied_domain_users
amacaluso: OK
amaguire: OK
blandry: OK
jcross: OK
root: matched denied_domain_users
sblanchet: OK
vadmin: matched denied_domain_users
Bill - Thursday, July 3, 2008 5:07 PM:
Try using this procedure http://www.aras.com/university/TechNotes/DocumentView.aspx?file=Aras%20Innovator%209.0%20-%20Client%20Cleaning%20Procedure.pdf and then log in again.
You could be caching bad credentials.
-Bill
blandry - Thursday, July 3, 2008 11:16 PM:
I did the entire IE cache clearing, but I was unable to do the .Net clearing the clean way that the doc shows as I do not have the .Net 2.0 SDK installed on my desktop.  I went to C:UserslandryAppDataLocalassembly (I am on Vista) and deleted those 2 folders, but I am still getting the same not authenticated error.
Brian
dmichaelson - Saturday, August 15, 2009 3:37 PM:
Just checkin in to see if there has been any resolution to this post, and if the question of how the communication between Aras and AD occurs.
Best,
Doug Michaelson
