JensRollenmueller - Friday, January 3, 2014 9:53 AM:
Hello community,
I am trying to implement new API - CreateCheckinManager into my application - but unforunately it does not support ItemCollections. With single Items it works very well.
Also CreateCheckOutManager supports Item collections!
I am using Aras Version 9.4.0.
Any ideas how CreateCheckinManager works ?
If you try this code in C# it will return: Not a single item / Parametername: configuration
Item itmCollect = Inno.newItem();
for (int iSubNbr = 1; iSubNbr <= 10; iSubNbr++)
string sFileName = @"D:TMP815-" + iSubNbr + ".txt";
if (System.IO.File.Exists(sFileName))
Item itm = Inno.newItem("File", "add");
itm.setAttribute("version", "0");
itm.setProperty("filename", (System.IO.Path.GetFileName(sFileName)));
itm.attachPhysicalFile(sFileName);
itmCollect.appendItem(itm);
if (itmCollect.getItemCount() != 0)
IomFactory factory = new IomFactory();
CheckinManager checkin = factory.CreateCheckinManager(itmCollect);
Item result = checkin.Checkin(2);
