SUPPORT Q&A - Is SQL itemtype in ARAS against SQL injection?
Rekha - Friday, January 3, 2014 12:29 PM:
It is suggested by ARAS support earlier to use stored procedure while updating a context item instead of applySQL and AML also does not work in this case.
I have created a SQL which has the stored procedure in it and updates a table in the database.
I am calling this SQL in my C# method.  I would like to know if this ARAS SQL protects against SQL injection just like the technique of parameterising a SQL query in an usual C# method?
Request you to help at the earliest.
Regards
Rekha
