DEVELOPERS FORUM - Cannot add physical file in a document
shantanu - Monday, January 13, 2014 11:06 PM:
Hi Guys,
I am new to our Aras Community. I had a serious problem while uploading files in a document. It gives an error while saving the Document after adding the file/files.
                 no items of type document file found
What can be the solution for this error? I am not able to find it.
Please help!!!!
gks - Thursday, January 23, 2014 4:12 AM:
Hard to tell what's the problem. But this can help a little bit further: Items of the type "document file" link the document with the file. Seems there is a problem creating them. (permissionsproblem?)
shantanu - Thursday, January 23, 2014 9:46 PM:
I am able to add document through root user. But when I checked the item type and compared with working instance I didnt get any loopholes.
vijayrsh - Thursday, August 4, 2016 12:17 PM:
I have the same problem. I have exact same error when a user is trying to add a document. I added user in "Can add" tab of item type  "Document file" but still no use. How did you fix it?
Thank you in advance
