SUPPORT Q&A - Cannot add a physical file into an Aras Document
shantanu - Tuesday, January 14, 2014 12:31 AM:
I am not able to add any physical file into the Aras Document with normal and admin user. With super user I am able to add those files. It gives following error while adding file/files.
No items of type Document File found
Please help me in this!!! It might have a basic solution or setting but I am not able to find it.
vijayrsh - Thursday, August 4, 2016 8:59 PM:
Hey Shantanu
Did you fix the problem? I have same problem even though I gave permission to the user who's adding document in item type "document file" in "Can add" tab. Please let me know how you fixed it.
Vijay
edonahue - Monday, August 8, 2016 12:18 AM:
Hi Vijay,
Are you trying to add the file programatically, or via the File relationship tab on the Document form? To start, I would recommend confirming that your user has Get/Discover permission on the File. Also, are you able to add a File as the admin user?
