SUPPORT Q&A - Innovator 10 Login Not Allowed
McNurlin - Saturday, February 1, 2014 4:53 PM:
So I've tackled a bunch of issues and can now get the login window to open with Firefox. When I try to log in with the "admin" "innovator" I get an error message saying that permission was denied. Below is a screen shot showing the error with SQL manager and the InnovatorServerConfig.xml file behind it.
gks - Monday, February 3, 2014 4:12 AM:
aviuradmin does not have the permission to run select on the table language on the database aviurplm.
did you modify the InnovatorServerConfig.xml manually? editing the db-connection for example.
McNurlin - Monday, February 3, 2014 11:01 AM:
I didn't really understand what was going on. I uninstalled Innovator and then reinstalled it leaving Innovator as the database login. It worked fine once I did that.
