SUPPORT Q&A - Error while saving
madmax33 - Monday, February 3, 2014 6:39 AM:
HI,
For one he projects that I am working on, I am getting the following error while saving.
No connection could be made because the target machine actively refused it 127.0.0.1:25
<SOAP-ENV:Envelope xmlns:SOAP-ENV="schemas.xmlsoap.org/.../"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="www.aras.com/.../faultcode><faultstring><![CDATA[No connection could be made because the target machine actively refused it 127.0.0.1:25]]></faultstring><detail><af:legacy_detail><![CDATA[No connection could be made because the target machine actively refused it 127.0.0.1:25]]></af:legacy_detail><af:exception message="No connection could be made because the target machine actively refused it 127.0.0.1:25" type="Aras.Server.Core.InnovatorServerException"/></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
This is happening to this particular project alone. The other projects are working well.
