SUPPORT Q&A - Exporting a drawing Package
spolen - Friday, July 11, 2008 8:09 AM:
 I was approached about exporting a drawing package, and when I researched this subject, I came across the exporting a package, but when I went to the Administration folder under item types/actions, I don't have the capability to import/export.  Do I need to order a CD, or is there a download for this action?  And if so, does this function have the capability of taking a top level BOM and exporting all documents associated with the top level drawing?
Sue
Anonymous - Friday, July 11, 2008 9:39 AM:
You can download the toolkit for package management, including the documentation, from the community projects site.  Look for the Solutions Upgrade Tool.  (http://www.aras.com/communityProjects/default.aspx)
This tool is primaraly intended for packaging the metadata of the database, and not the instance data, though.  I am not sure it will meet your needs.  I suppose it depends on what you want to do with the export once it is out of the system, but I suspect you are better off writing a custom method for this export.
spolen - Friday, July 11, 2008 10:10 AM:
Thanks for the heads up.  It will still help when doing a data dump, instead of having to enter everything manually, which we have had to do since adopting Innovator.  I'll see if IT can come up with a script to help me with my needs.
Thanks Again!
