SUPPORT Q&A - ItemType Report Error
mationchen - Tuesday, March 18, 2014 12:37 AM:
I use Innovator 9.3 ,OS Win2008R2(x64),sql server2008R2
when I click -->ItemType --> Report -->ItemType Definition Report Or the other 2 report ,
I have got an error message below,
then I install msxml4.0 sp3 in my computer,but still I get this error message.
Last night,I install Innovator 9.3 in Win2003(x32), and those reports are correctly showed.
My Question is How Can I Get these Reports In Win2008R2?
Thanks all!
ERROR MESSAGE:
Error occurred while creating MSXML COM objects. Code: 0xc0000073 Could not create the 'MSXML2.DOMDocument.4.0' object. Make sure that MSXML version 4.0 is correctly installed on the machine. <SOAP-ENV:Envelope xmlns:SOAP-ENV="schemas.xmlsoap.org/.../"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="www.aras.com/.../faultcode><faultstring>
Code:   0xc0000073
</faultstring><detail><af:legacy_detail>
Code:   0xc0000073
</af:legacy_detail></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
