DEVELOPERS FORUM - Populate "field codes" on a document with metadata from Aras?
BMoberg - Monday, April 7, 2014 8:15 AM:
Is it possible to automatically populate a word/excel document with metadata from Aras, during checkout/view?
For example using "field codes" in the header of a document, to "pull" information from Aras, such as document number, name, state and revision.
Example: using field code {Document property state} to pull the document state.
I have not studied the document handling in Aras yet, but as this is a central CM-feature, I assume that it is possible in any way.
zahar - Monday, April 7, 2014 8:19 AM:
If you Aras subscriber, there is "Office Connector" that you checkout Office documents with can map data from aras to document and back.
But again you need to be Subscriber
BMoberg - Monday, April 7, 2014 8:28 AM:
Thanks for the reply Zahar,
Yes, I just saw that there's a office connector, and that's a great feature.
The problem is that I need a temporary solution, in testing purposes.
