DEVELOPERS FORUM - Check Item number and allowing for generating report.
tin - Monday, April 14, 2014 9:38 PM:
Dear All,
I need javascript method for preventing from generating the report.
For example, Part-->Item number starts with D001-> right click select "Test Report" it should allow the user to generate the report.
Whereas the Part--->Itemnumber starts with T001--> right click select "Test Report" it should prompt message stating it is not applicable for this selected Item number.
I have designed the Report but i dont know to do validation in Javascript method and linked with the xslt report.
Can you anyone tried this before,then please guide me.
Tin.
DavidSpackman - Tuesday, June 10, 2014 11:42 PM:
Hi Tin,
Here is something that could be modified to do what you want.
On your report, set the location to client, and set a similar javascript method.
You should be able to use this.getProperty("item_number",""); to get your property value.
var a = top.aras;
var tmpDom = a.createXMLDocument();
var parenId = this.getID();
var reportQuery;
var retVal;
reportQuery = '<Item type="Meeting" id="'+ parenId +'" action="get" select="">' +
  '<Relationships>' +
    '<Item type="Meeting Action Item" action="get">' +
      '<related_id>' +
        '<Item type="Action Item" action="get"></Item>' +
      '</related_id>' +
    '</Item>' +
    '<Item type="Meeting Participant" action="get"></Item>' +
  '</Relationships>' +
'</Item>';
tmpDom.loadXML(reportQuery);
var r = a.applyItem(tmpDom.xml);
if (r && r.indexOf("<Result") < 0)
   r = "<Result>"+r+"</Result>";
var reportNm = "Meeting Minute Agenda";
var reportNd = a.getItem("Report", "name='"+reportNm+"'", "<name>"+reportNm+"</name>", 0);
//debugger;
if (reportNd)
     tmpDom.loadXML(r);
     var xslStr = a.getItemProperty(reportNd, "xsl_stylesheet");
     retVal = a.applyXsltString(tmpDom, xslStr);
else
   retVal = "<H4>Report (name="+reportNm+") not found</H4>";
//Return nothing
//return;
//Open an new page to display report
return retVal;
