Vardhan - Tuesday, April 15, 2014 6:11 AM:
Recently I installed 10.0 on Windows 7 machine. I wanted to add an extra column(Classification) to Part's Multilevel BOM Report, but the stylesheet code for the report is empty. And the generated Mulitilevel BOM report is:
I am facing same issue with all standard report's stylesheets. I tried to copy the Stylesheet code from 9.3 and Paste in here, after save I can see only the HTML(<html>.....</html>) part of the code that I copied. I am facing the below error if I click on 'Apply' button for all Reports.
Apply change error: XML Parsing Error: mismatched tag. Expected: . Location: localhost/.../Innovator.aspx Line Number 1, Column 82:
How to solve this, and how to see the original code of Report's stylesheet?
Thank you.
Brian - Sunday, May 11, 2014 9:56 PM:
Hi Vardh,
See this post on the same problem.
www.aras.comhttp:/.../4613.aspx
Hope this helps,
