KamranAftab - Friday, April 25, 2014 9:11 AM:
Hi All,
I successfully installed Aras 10 yesterday and it was working. However, this morning, when I restarted my machine it did some windows updates, and now when I double click the Aras shortcut, the Internet Explorer 10.0 window comes up blank. The address bar shows:
localhost/.../default.aspx
Thanks in advance for all those will help.
Kamran Aftab
Mark.Veldhoff - Monday, July 21, 2014 5:24 PM:
Kamran -
Were you ever able to get your issue resolved? I have the same problem. Aras 10, Internet Explorer 10. The page goes blank with this URL: XXXXX/.../default.aspx.
I have double checked the IE settings. I have verified that the correct address is setup in the trusted sites and ran the sdns tool from the desktop as admin.
The installation works correctly from firefox so I do not believe it has to do with the setup.
The local host is the IIS server windows 2012.
MAV
KamranAftab - Tuesday, July 22, 2014 10:25 AM:
Mark,
I did not remember at all what I had to do to make it work. So I just went through the exercise again. It seems like adding localhost to trusted sites did the trick. Here are the steps:
Internet Explorer --> Tools --> Internet Options --> Security --> Trusted Sites --> Sites
Add http://localhost
I don't believe I had to run dns.
Please update this post with your results.
Kamran
KamranAftab - Tuesday, July 22, 2014 10:27 AM:
One more thing. When I pressed on "Add", I got the message that it was already in the trusted sites. I added it regardless, and then it worked.
pankaj - Wednesday, July 23, 2014 2:46 AM:
Kamran,
Again you need to run sdns and check for IE setting.
Pankaj B
KamranAftab - Wednesday, July 23, 2014 8:39 AM:
Pankaj,
Why do I need to run sdns and what setting in IE? Why would I care when it is all working fine?
