DEVELOPERS FORUM - Version Upgradation ...
sagar_makhesana - Thursday, May 15, 2014 8:52 AM:
Hello Friends,
While i m trying to Import a Package From  9.3 to 9.4
I got  an Error Message as per screen given Below.[ String or Binary Data would be Truncated ]
How to overcome with this Problem?
Thanks in Advance :-)
Sagar Makhesana
Brian - Sunday, May 18, 2014 9:30 PM:
Hi Sagar,
There should be more information in the log file pointing to which Item type encountered the problem.
Basically the item type you are importing into  has an existing field/element that is shorter than the data you are trying to import.
Find the item type, have a look in the 9.4 system and compare the size/length of the fields. When you find one that is shorter in 9.4 than in your 9.3 then make it bigger.
Hope this helps,
The screen shot did not post so I could not see additional information.
sagar_makhesana - Monday, May 19, 2014 2:36 AM:
Hello Brian,
Thanks for Help :-)
Log file Helps me to resolve Issue. There was little change in OOTB Schema .
Sagar Makhesana
