DEVELOPERS FORUM - AML to add project
robos - Monday, June 2, 2014 3:01 AM:
Can you help me with minimal AML needed to open a new Project ? I tryed with this one, but it looks I can't handle WBS in a proper way. Probably it should be entered/created as dependency.
<AML>
  <Item type="Project" action="add">
   <name>Test</name>
    <date_start_sched>2014-01-01</date_start_sched>
    <date_due_sched>2014-06-01</date_due_sched>
    <wbs_id>Item type="Test"</wbs_id>
</AML>
kentonv - Wednesday, June 4, 2014 4:06 PM:
Unfortunately, most of the code for project creation (from a template) is client-side, so it is difficult to create a project that includes a template.
If you are not looking for template capability, you can modify the code as below to create the project with a single wbs item.
The AML you show would not work since the <wbs_id> is expecting a real new wbs item id.  It is also not possible (in my testing) to include the WBS Element in the <wbs_id> tag, since the order of events causes an error.  In a method environment, you could call the first <Item> tag, retrieving the ID, and use that in the second call.  Otherwise generating an ID from a GUID is relatively simple.
<Item type="WBS Element" action="add" id="FA71468937574007A694FC914B249862">
  <name>Test Project</name>
  <is_top>1</is_top>
  <date_start_sched>2014-07-01</date_start_sched>
  <project_number>1194</project_number>
  <date_due_sched>2014-07-31</date_due_sched>
  <scheduling_type>Forward</scheduling_type>
  <wbs_id>FA71468937574007A694FC914B249862</wbs_id>
robos - Thursday, June 5, 2014 6:44 AM:
Thank's for your valuable input,
I checked now the client side code and I saw that the whole logic is there as you said.
I had template capability in my mind
