SUPPORT Q&A - Login fails on error - The statement terminated
JKo - Tuesday, June 24, 2014 3:16 PM:
Normal 0 false 21 false false false FI X-NONE X-NONE
We are running Innovator 9.4.0., build 5804. We've had couple of different 9.x.x version in use for years and each has worked fine until now.
Today we have been unable to login due a script error or an SQL error. Not sure which, or both. Innovator opens a webpage error dialog with a following error:
"The statement terminated. The maximum recursion 100 has been exhausted before statement completion"
I can't figure out what causes the problem. We added couple identities to existing groups and normal work was ongoing as usual. Then a user reports this issue.
Is there any known reason for such error? Suggestions how to fix the issue are welcome. Wouldn’t like to install Aras all over:)
JKo - Wednesday, June 25, 2014 4:28 PM:
It seems that there went something wrong when we added identities... Anyway, I took a backup and deleted all new entries from the database table innovator.MEMBER. Now the login works again.
